I have an early big max that had the 2 cylinder 2-stroke engine. It ran ok strong with a scary top speed but was very finnicky with the carb and no climbing torque. I decided to install a 20 hp onan 2 cylinder 4 stroke engine. went in great runs strong but the driven clutch will not open up. it is free and I can pry it open easily. the drive clutch moves in smooth and easy with no belt on the clutch , but once i install the belt you can see it try to pinch the belt but the driven clutch won't open up . do I need to change the yellow large spring on the driven clutch or mess with the rollers inside the drive clutch. Since the new engine probably only spins up half the rpms max. Those rollers might not be pressing out hard enough. It runs and drives around great but at like 3 mph top speed with the touque to climb my house.any help would be greatly apprieciated. jeff.
a 2stroke clutch will not work on a 4 stroke unless it is reworked inside.someone may know how i donot hope this helps abit
