I need some advice on my T-20 tranny situation.
Some quick background (or as quick as possible): I bought this 2000 Max IV back in October, 2009. It was supposed to be in great working order, so I paid around $4,500.00 for it. But, it turns out I took a beating on this machine, only the 25 HP Kohler works well on it.
I spent every available evening and weekend for three weeks and over $500.00 ripping the engine and tranny out and fixing and replacing various aspects of the drive train: chains, sprockets, bearings, etc. Finally, I got it all fixed up . . . I thought . . . and put it all back together. I took it for a test drive or two, and then the T-20, itself, went out on it . . . stranding me a couple miles from home. (Something happened to the left side wherein it wouldn’t brake going forward and wouldn’t drive in reverse: bands, I guess.)
So, I ripped the engine and tranny out again. Fortunately, my brother had two, old T-20’s from an old Chaparral that he had. The one worked great the last he used it, and the other had a frozen diamond, forward/reverse shifter on the right side. So, we decided that I would just rob that old, working T-20 out of his Chaparral, as his machine did not work right now, anyhow. I had to do some modifications, as this older T-20 had the eye-bolt style steering linkage. Then, I put it all together, but I noticed a minor problem during my first test drive. The secondary, driven clutch would open up and hit the chain at high-end.
So, I ripping the engine and tranny out AGAIN and then installed the two spacer washers that were on my original T-20 onto this replacement T-20 to shim the secondary, driven clutch out away from the chain. I put all back together AGAIN!!! (This is now four months since I bought this Max IV and the third go round of ripping the engine and tranny out and making repairs and then reinstalling everything . . . and all before I took a single pleasure ride or even used an 1/8 tank of gas.)
After getting everything back together this third time, I took it for a test ride. At first, it worked great. But, when I went to put it into reverse to back it into my garage and declare this all FINALLY to be a success . . . this second T-20 went out on me!!! Oh yes . . . I AM serious!!! It wouldn’t go into reverse, and then something jammed so that I also couldn’t get it into forward, either. It was something with the diamond, forward/reverse shifter on the right side . . . just like my brother’s other old T-20 had wrong with it.
DING . . . DING . . . DING . . . NOW ROUND FOUR!!!
That is where I am, now. I have the engine and tranny ripped out for the fourth time . . . which brings me to the point of this email:
What do you folks think I should do now??? Obviously, I need to tear apart and rebuild one of these T-20’s. But, I am not sure if I should rebuild the original, newer T-20 or the older T-20 that has been modified for my purposes. Are the newer ones better in some way??? Are the parts NOT available from Recreatives for the older ones??? If either of these is the case, I will rebuild the newer one, but otherwise, I am leaning towards rebuilding the older T-20, as I like that eye-bolt style of linkage better . . . plus, I have two of those older T-20’s, so maybe I could do some mixing and matching with those two older T-20’s. On that note, are the internal parts of the various models of T-20’s different??? Or, are the gears and bands and so on the same across the years???
Sorry for the long post, but I felt that for you to be able to help me best, you would need this background.
Thanks in advance for any help you can offer me.
