t-20 hours
  • t-20 hours
    is it true that u have to change the trans fluid every time u change your oil which is about every 50 hours
    I would say its true. Put a ball valve and hose barb in place of the drain plug. Lift front end with winch , place 1 gallon zip-lock bag under hose barb and open valve. 10 minute oil change. I usually run the machine for a few minutes to get the fluid warm.
      ok yeh that is actually a great idea and its a good for changing the oil too thanks
        Gm makes a transfer case fluid called "AUTO TRAK II". It is great stuff and stops the xfer case shutter that occurs when the clutches slip/grip/slip/grip making them operate much smoother. I think it would work well in a t-20 and eliminate the need for limited slip additive. It may also stop the band shutter common in t-20's. Who is brave and wants to try it?
