got the hustler running tonight and with the machine up on blocks, started running everything through it's paces. found that reverse doesn't work on the right side. adjusted all the plungers, still no go. took out the diamond shifter and the pin was worn, flipped it over and tried again... still no go. normally at this point i would be thinking band/ drum failure except it has braking on the right side when the trans is in forward. is it a pretty safe guess that the teeth are stripped off the gear selector in the trans? seems like the only logical thing it could be to me, but it's one i've never heard of. I'm going to pull the trans next week when i get home from Ashtabula unless someone can think of something i might be missing
the only spare 18 tooth drums i have have been machined 15 thousandths. they were going to go into a spare trany with new bands. looks like i need to source a new drum.
