Well I sat down and started taking apart the T-20 today. Wow was it ever fun
If anyone has a tool that removes the inner output shaft snap ring, please let me know. It is not easy to remove (as Mike says in his article) but I managed using some snap ring pliers. I am including a couple of pictures so I can get some opinions on the two bands from the right case. I haven't broken down the left half yet...probably tomorrow. Anyway my guess from the looks of the 2 bands is that the bad one is obvious and will need to be replaced
Without seeing the other two yet I am betting they will look the same.
Al
Without seeing the other two yet I am betting they will look the same.Al
I also noticed that my plungers on the bottom of the case have 2 o-rings and the ones on the top have just 1. Is that standard? I guess it would make sense because the oil is going to mainly sit on the bottom...Thanks for the tip!
