1). What kind of oil should be in the tranny ?
2). With the transmission on the bench when I turn the clutch shaft by hand the power to the idler shafts seems to have some back lash. Also if I hold one of the idler shafts I can stop it (while turning the clutch shaft) Is this normal ?
If I twist the idler shafts it seems to have good friction to the clutch shaft (does that make sense ?)
3) There seems to be a dip stick in this transmission. The dipstick is hollow and has a small pin hole near the top of the tube. It also is open right to the top of the housing at the brass part. Is this normal ?
4) There seems to be an aluminum plate on the left side of the transmission. Between the clutch and the housing. Is this normal ? (The plate passes across the clutch shaft seal and appears to be attached into factory forged bolt holes)
This pic shows the plate:
