I just dove into my 4th T-20 rebuild of the summer. looks like this one sat parked on a side hill with the right side down for a long time! everything on the right is in beautiful shape, and everything on the left is rusty. when i tore it down, the input shaft bearing stayed on the shaft and pushed the seal out with it. the bearing won't turn at all, and i suspect the needles are rusted to the shaft. I can cut the bearing off and polish the shaft out no problem. i'm just wondering if this is a standard bearing that i can pick up at the local bearing house, or something i have to get from RI? all the other parts polished up pretty well and the only other thing i've found that needs to be replaced (besides seals and bands) is an output bearing (which i have), and a detent spring (which i may have
I know that the output shaft bearings are special, but the needle bearings for the sun gears can be sourced locally. i've never had to replace the input bearing so i thought i'd throw it out to the experts.
anyone know if this is a standard bearing, and anyone have a part # for it?
)I know that the output shaft bearings are special, but the needle bearings for the sun gears can be sourced locally. i've never had to replace the input bearing so i thought i'd throw it out to the experts.
