need a little advice before i button my old argo back up.while testing my clutches i observed that the driver clutch is offset from the driven clutch about 1/4".this seems to be perfect for when the sheaves open up but at idle,the driven is being drove when in neutral.this causes the trans to grind when its put into gear.when im in gear i can hold the brakes on and shift with no grinding.is this normal?
cheers.
cheers.
