i have a hustler 950 and im afrade i am not putting enough fluid in it.it says t20 30 and i was told to put one quort of fluid in it or fill to the seckond hole.well thair is one at the bottem and one at the top.filling to the top is 3 qurts.help what do i do
hustler t20 help
Always fill through the top hole until it runs out the bottom hole. That is the 1 quart full line. If you add more, it will run out of the bottom drain plug (hole). You'll never be able to get all of the fluid out of the transmission when it's in the machine, unless you're the Amazing Kreskin. (who is a complete Charlatan, by the way....)
One quart of ATF. No more, no less.
~msigpic
