Are there sprockets available for the t-20 trans with different number of teeth on them? If so, where can you get them? I am increasing the tire size on my hustler, and I would like to decrease the number of teeth on the t-20 sprockets so I do not lose low end torque. The sprockets now are 15 teeth, I would like to go to 13 or 14 teeth. Thanks for any help.
T-20 sprocket question
You used to be able to get other sprockets, but I'm not sure how many teeth they had. Recreatives will be able to tell you if they're still available. If they're out of stock, the only other source I know that may have some is Richard's Relics. It may be easier to make yourself some center axle tubes with larger sprockets. Good luck.Stuck in the seventies- not in the swamp.
Cool, Whipper. I don't think I saw that thread- shoulda known! Nice work.Stuck in the seventies- not in the swamp.
I just had to try the F.B. Like button on that. I know the racer will need a re-Gear, and with a spare tranny that'll make it easier to change ratios fast
(Oh God, I feel like a Crack addict needing a Fix. I need my racer.....NOW!)
Attex Super Chief - Sold.
Kunzmm,
Im Eddie and I know this is what you are looking for. It worked out great on all the work Whipper did on the trans."Like none of us , didn't know that" when you do that also replace the GREEN spring with a RED spring on the trans clutch. That will also help out a lot and you will see a big diff.Good luck on it, hope this helps you .
