Ok so i read the posting on how to adjust tranny but how the# $%& do you adjust it while its in the body i have a max 2 and i did my best but i had no way to measure the bottm like your suppose to so i just eyeballed it is there anything i should worry about i rode it forward backward turned left and right it even steers better and not as jerky as it was if adjusted wrong will bands where out quiker or will it be fine i have had alot of issues with going straight i have to keep workin the controls i dont go fast but its still annoying i also dont have the tool either to adjust
t20 adjustment
The "U channel" design was about the worst mod R.I. ever thought of. http://www.6x6world.com/forums/trans...html#post73766
I put the shoulder bolts on mine, and it's great
(thanks for the idea whipper)
Once you get the travel on each plunger equal to the others the adjustment is easy.
You don't need any special tool either. Just use a thin walled socket and remember to turn both bolts the same amount in 1/6 turn increments.Attached Files
