JUST TRYED TO BACK MY ATTEX OUT OF GARAGE,I COULDNT GET IT BACK INTO FORWARD-TRYED USING A SCREW DRIVER ,REVING A LITTLE THEN ENGAGING NO LUCK,HELP WHAT SHOULD I LOOK FOR?
T-20 wont shift
not sure what the weather is doing in PA right now... you may just have some moisture down in the bores that the shifters go in and it has frozen.A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed.
first thing to try would be spraying some lube down in the shifter bores. if that doesn't get it moving freely, pull the diamond shifters out and see if you can move the shift collars manually. (use a screwdriver to try to move them in each direction. your shift pins may just be worn to the point where they are allowing the diamonds to travel too far and bind the linkage. on the older t-20's the shifters were held in with a snap ring under the diamond. that ring is a royal PITA to remove. i just bend the end with a screwdriver then tear it out with needle nose pliers, then replace the ring when going back together.A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed.
you can replace just the pins. they are about $5-8 from recreative. put the diamond in a vice, remove the O-ring, heat the barrel of the shifter with a propane torch, grab the pin with vice grips and twist/ yank it out. if the other side of the pin is in good shape you can just flip it over and reuse. i install mine with a drop of red loctiteLast edited by racerone3; 12-19-2010, 11:33 AM.A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed.
R.I. sells the pins, I think they are $2.50 each. but they can be hard to get out.
There was a post a while back with another source, if I remember right they were $15 per 100........who needs 100????? Maybe somebody who bought the 100 would sell a few.
I wouldn't mind having a couple spares myself.
last time i bought one from RI it was 8 bucks and the shipping was 6
here is the thread regarding the dowel pins from MSC http://www.6x6world.com/forums/trans...ness-test.htmlA well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed.
Hey Brian, how are things going?
I haven't ordered any yet, but probably should, just to have them on hand if/when I need them. Might save me some down time,waiting on them. I order a LOT of stuff through MSC at work and usually get it in a day or so.DESTRUCTION is just a couple of vowels down the street from DISTRACTION
I never ordered any from MSC either. Last time I needed one, i got 2 from RI so I still have a spare. I also have a spare diamond shifter that i drilled a second hole in. it lives in my "trail bag" with a pin taped to it. that way if i break one on the trail i can just push the pin into whichever hole it needs to be in and go.A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed.
