a friend put the 2 shifters in his max 2 for it to CR . it will not . need some ideas thanks. robbie
couter rotation max
couter rotation max
1999 max 2 18 b&s 22 tires custom . new max iv 23 k 26 i/n tires brown . ht cable promark winch . new toy 1972 attex st400 400ccjlo and she will be bad . ( the frog )if it don't float with out you getting wet . don't bring it !
R.I.P sage rogers 4 11 09 .
Tags: None
u hit the nail on the head jest sit's there
.robbie1999 max 2 18 b&s 22 tires custom . new max iv 23 k 26 i/n tires brown . ht cable promark winch . new toy 1972 attex st400 400ccjlo and she will be bad . ( the frog )if it don't float with out you getting wet . don't bring it !
Well I would check the belt or not sure if it was you driving it or not but also it is kinda complicated on the correct position of the sticks for it to work right. You know when your in reverse it works backwards but when you are in both forward and reverse it gets complicated, lol. The one I did I only drove a little bit but I had to actually think of where they had to be, I couldnt just do it second hand. Maybe with more time with it but I never did.
thanks larry . he will see this / robbie1999 max 2 18 b&s 22 tires custom . new max iv 23 k 26 i/n tires brown . ht cable promark winch . new toy 1972 attex st400 400ccjlo and she will be bad . ( the frog )if it don't float with out you getting wet . don't bring it !
Ok I talked to him on pm and thought I would post what he is finding to possible help others. He says it works fine off the ground on jack stands but not on the ground. My guess is a belt issue or possible the bands need adjusting. Something must be slipping. Counter rotating takes a lot more power so what ever is slipping when you counter rotate might not be so noticeable during normal driving.
ok coollllllllll thanks larry .1999 max 2 18 b&s 22 tires custom . new max iv 23 k 26 i/n tires brown . ht cable promark winch . new toy 1972 attex st400 400ccjlo and she will be bad . ( the frog )if it don't float with out you getting wet . don't bring it !
Originally posted by LarryW View PostOk I talked to him on pm and thought I would post what he is finding to possible help others. He says it works fine off the ground on jack stands but not on the ground. My guess is a belt issue or possible the bands need adjusting. Something must be slipping. Counter rotating takes a lot more power so what ever is slipping when you counter rotate might not be so noticeable during normal driving.
It does seem a little backwards to push on one stick while pulling back on the other....I bet that is the issue...oterwise look at the diamond shifters to make sure they are where they should be.
Sorry to disagree with you disagreeing but how many tires are powered during a skid steer verse counter rotate? What the brakes were doing the engine is now doing. The Machine is trying to go forward and backwards at the same time. How can that use less hp?
I also think counter roatating takes more power than skid steering. I split the shifters in my Max IV and it takes a lot more power to counter rotate from a dead stop. How I get around it is to start moving with one of the sticks in neutral position and once I start moving, engage the other side.
I am going to agree with larry and liflod on this one. I tried this with my hustler from a dead stop once. The engine bogged down and struggled, but the machine never moved. Yet it has no trouble turning normally.I don't want to go fast, I just want to go anywhere.
i have the split shifter in mine and it does take a alot more grunt to counter rotate from a dead stop i use the same technique i start one side rolling forward then engage the other tires it works quite well my spit shift has got me out of alot of sticky situations1996 MAX IV ,KUBOTA DIESEL
MAX II 30HP Bandolero
Robbie,
is it possible that he is not pushing and pulling on the appropriate sticks fully? I found with my Hustler it wasn't natural to push and pull then hit the gas."Don't worry my Dad's a TV repairman, he has an excellent set of tools..I can fix It"
micmac he's doing it . we think his cluches might be the problem . thanks robbie1999 max 2 18 b&s 22 tires custom . new max iv 23 k 26 i/n tires brown . ht cable promark winch . new toy 1972 attex st400 400ccjlo and she will be bad . ( the frog )if it don't float with out you getting wet . don't bring it !
