I inherited an older Argo (Magnum I believe) project that was part way through an engine swap from a Kohler 18 to a Vanguard 18.
The engine was bolted in but had never been started, and the drive clutch was mounted to it, and the drive belt was on. I messed around electrical stuff the first couple of nights I worked on it, and last night got it to the point where the motor was ready to fire it up.
Once the engine was running I tried to put it in gear but it just grinds so I stopped right away. Apon further inspection I noticed that the drive clutch seems to be engaged even when the motor is idling. The belt still spins... I assumed this was my problem.
But then I also noticed the belt seems too tight as well, and seems to ride much deeper in the driven clutch than in other pictures Iv seen... its at least a couple of inches inside the outer edges of the clutch (picture below).
Is my belt to short for where the motor is positioned?
How tight should the drive belt be when the motor is turned off and the machine is in neutral?
Do I need to remove one of the clutches to remove the drive belt?
