how do u adjust the bands in the trans. mostly the forward drive bands they are weak
adjusting drive bands
Check all of your linkage all the way back to the T20. Make sure you are pushing forward on the sticks hard when you go forward. If everything looks fine then you may need to adjust your T20. If you will use the search there are a lot of threads on how to do that. Here's a couple to get you started:
