I have a 2001 Max II Just bought it last week. I decided after riding it for about 1.5 hours that I had better chang the fluids, tighten the chains ect... The transmission felt off, like maybe it needed adjusted as well. SO I do the whole nine, and adjust the left side a tad. Then after an hour trying to get something on that square plug in the tranny to drain it I get it loose. I am expecting fluid to come out...nothing. Then I run my sludge gun tube into it, pull back and about 4 oz of red crap comes out. SO I know it holds 32oz, which should be 1 quart of in my case B&M trick shift, and 4 oz slip additive. I am expecting it to hold only half quart or so, cause not alot came out. To my surprise it held 4oz of additive, and 24oz of fluid 28oz! before running out of the bottom hole.
Question: Where did the fluid go? This is an extremly low hour machine, it looks 85% new. Even the inside tub isnt all greasy. What I am saying, I dont think I have a leak. Was it never changed and it evaporated? Burned off? Maybe someone drained it, and didnt come close to putting enough back in? How bad has this damaged the T-20?
Crazy fact...Trick Shift by B&M went in, I sealed it up, started it and ran it for a half hour...I have owned 3 of these machines, this one is the most responsive and smoothest by far. Tranny feels great (now that it has fluid). SO whats your thoughts? Are they just that tough?
I highly reccommend Trick Shift BTW...$7 quart at autozone...synthetic ATF replacement.
Please share your thoughts!!!
