Saturday I was warming my machine up getting it ready to put on my trailer. When I put the machine in reverse and gave it gas the machine wouldn't move but made a small grinding noise that let me know it wasn't in gear.
I shifted into drive and the machine made the same noise but wouldn't move.
My mind shot back to RD's and BW6's post where they talked about new HDI's that wouldn't move when the owners engaged gears but the machines just made a grinding noise.
No way I thought. I reached up and shifted the machine into low range and hit the gas and the machine started to move. I breathed a quick sigh of relief and took the front panel off and looked at the shift mechanism which is spring loaded and activated by a cable switch on the dash.
The cable tension is adjusted with two bolts, one for adjustment and the other to lock the adjustment into place. This cable Stretches over time and must be adjusted to keep the spring loaded shift mechanism working properly.
In my case it was just a minor adjustment and I was on my way. So Admiral owners if it happens to you don't panic, make the adjustment and you'll be on you way.
