okay, its 2:45 foggy brain am. i looked at the t20 rebuild twice and didnt see any torque specs for the allen bolts, but.... my book says 12 to 20 INCH POUNDS. whats that? hand tight with an allen wrench?
torque for t20 housing
If it is inch pounds you will need a torque wrench that reads inch lbs.
Here are a few samples of the different kinds: Inch Pound Torque Wrench: We have inch pound torque wrenches.Life should not be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways , cigar in one hand, whiskey in the other, body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!!!"
Sherman's right... your ft/lbs torque wrench might not be intricate enough to actually read the right number in inch-pounds, but the conversion is right.Originally posted by sherman View Postif it is inch pounds and you have a foot lb. torque wrench just take your foot lb and divide by 12 to get inch lb. and there you have it
Online Conversion - Torque Conversionsigpic
i discussed the divide by 12 with a guy last nite and we thought maybe that wasnt right, upon reading above post remembering along line of 20ft/lbs, i started out to the garage to re-read manual but its freezing rain here so i'll check tomorrow. thanksi have tools, and i have hands, its the filler between my ears thats missing.
Actually Sherman's statement was a little fuzzy......Many of us understood what he meant, and figured you would also. Anyway, here is a clarification. 12 inch pounds= 1 foot pound. So if you have a number in inch pounds and would like to know the equivalent ft/lbs, you would divide by 12. If you have the torque spec in ft/lbs you would multiply by 12 to get the correct number of inch/lbs.Originally posted by applejack View Posti discussed the divide by 12 with a guy last nite and we thought maybe that wasnt right, upon reading above post remembering along line of 20ft/lbs, i started out to the garage to re-read manual but its freezing rain here so i'll check tomorrow. thanks
okay.thanks. but it looks like thats the least of my concerns now. as i stated in another post, my bands have SOME CRACKS, although i didnt take them out, it looks like they're only the 1st 2 inches from the retainer at the top. the next question is, do i NEED to change them? i expect the general concensus to be, "since you're in there............." waaaaaaaa!i have tools, and i have hands, its the filler between my ears thats missing.
If a chunk of the band lining comes off and you end up with some steel-on-steel action, you'll have to open it up anyway and repair a far more expensive part, and end up replacing your bands regardless..Originally posted by applejack View Postthe next question is, do i NEED to change them? i expect the general concensus to be, "since you're in there............." waaaaaaaa!sigpic
