no color all rust but i was using a spring rate tool found one alittle stiffer and has a higher rate as you compress not like the argo stock ones ill have to take the clutch apart to find out the rate if you want
Argo Conquest clutch springs
it brought the engagement rpm from 1000 to 1300 and had to adj the gov to rev the motor to 4000 to close the clutch but works awesome upshifts slower and down shifts quicker on hills and in mudif you think you cant just try it any way you wont know till ya do
If you get a change that would be cool. Get the load at 72mm and 45mm and we can cross reference with this chart. Compressed length would be good to know too.Originally posted by Tickles View Postno color all rust but i was using a spring rate tool found one alittle stiffer and has a higher rate as you compress not like the argo stock ones ill have to take the clutch apart to find out the rate if you want
