based on recommendations, i am removed my t20 from the max.
i have three questions
1.what is the recommended way of removing the driven torque converter from the transmission input shaft? there are no holes to put a pull on it. a three jaw puller may bend the outer disc of the pulley.
2.who is the most economical but still does a good job on relining the bands on a transmission?
3. does anyone have the dimensions for cutting a second groove in the plungers for a second O ring...or is this not recommended? i have a lathe so i could cut new o ring grooves...and i have read on richards relics that this is an upgrade.
bonus question!!!!!!
4. assuming that as the bands wear, the plungers will pull out further and further, and also assuming that the refinishing of the drums does take place, reducing the size of the drum slightly, how far out will the plungers pull in a rebuilt and a worn transaxle
bonus question number 2!
i read that ther should be a quart of fluid in the transaxle. when i filled mine, there was some residual oil and the oil came out of the bottom drain plug before i put in an entire quart..for example, i only put in half a quart. when i drained it, there was not an entire quart that came out...and none of leaked out as i just filled itsaturday.
the way that the drain plug is oriented, i do not think that an entire quart would go in without reaching the lower drain plug...or am i missing something?
thank you for your help
chris
chris
