brake disc removal
  • brake disc removal
    I've used the search function here and googled several times. I'm trying to get the brake disc off my '98 response. I've removed caliper and clutch. I'm trying to remove the large disc which has the double sprocket on it. What am i missing? Thanks in advance.
    should be one bolt in the center of disc.remove it then tap the disc off of the shaft.
      Ok thanks. I've removed the bolt, but it's stuck. I just wanted to be sure piror to using a little more "encouragement" that I wasn't missing something simple. Thanks again.
        hose it down with some pb blaster and let sit overnight.will seep around the shaft and into the keyways.
          You might have to lift the cradle up a little so the disk clears the gear on the idler shaft.
