Again, the manual and reality don't match. The manual says to fill to the dip stick line, and the transmission should hold .85 liters or about 1.8 US pints, or about 30 onces. When checked, the fluid level was high. I drained the transmission and replaced the oil with 30 oz (measured) of a Hypoid gear oil. Guess what, the dip stick still indicate I have too much oil in the transmission. So is the dip stick wrong or is 30 oz too much oil? Anyone else have this problem?
Transmission Gear oil
I would imagine the 30 oz is when the transmission is completely empty. I doubt that you emptied it completely when you drained it so just drain some more out until it is at the full line.Originally posted by Paul219 View PostAgain, the manual and reality don't match. The manual says to fill to the dip stick line, and the transmission should hold .85 liters or about 1.8 US pints, or about 30 onces. When checked, the fluid level was high. I drained the transmission and replaced the oil with 30 oz (measured) of a Hypoid gear oil. Guess what, the dip stick still indicate I have too much oil in the transmission. So is the dip stick wrong or is 30 oz too much oil? Anyone else have this problem?
