2 stroke to 4 stroke
  • 2 stroke to 4 stroke
    I am looking at repowering a 2 stroke powered 6x6 with an honda knock off 15 hp engine .Are there any adaptors outhere that will adapt from a 1 inch keyed shaft to a 30 mm tapered shaft so I can use the existing primary clutch that came on the factory engine?
    JerseyBigfoot told me there are adapters for the other way around so maybe.
    You will need to change the spring/weight combo in both clutches though. The 2-stroke engines spin at much faster RPMs than a stock 4-stroke and both clutches in a two stroke machine are probably set up with that in mind.
