T-20 Dimmensions
  • T-20 Dimmensions
    Could some tell me the overall width of a T-20 and also the distance between the two output sprockets?
    I am considering using one in my playcat.
    Thanks.
    Are you looking for the width of where the mounting points are or the width of where the output sprockets are?
      Output sprockets. Overall width would be nice too.
        My T-20 just happened to be out of the Max II sitting on the floor. The two output sprockets are ~15 inches center to center. Both output sprockets are (naturally) 7.5 inches from the transmission centerline. On one side is the input shaft. My input shaft has the clutch on it and it is about 13.75 inches to the outside edge of the clutch so overall width on mine is about 21.25 inches. But if I remember right the clutch hub hangs over the input shaft by about an inch so it may only be about 20.25 inches overall - I can't measure that.
