Clutch Help
  • Clutch Help
    I am new to the sport, bought a 2002 Max IV a couple of months ago, replaced the left rear axle/bearing/sprockets/ drive chains off of the t20. Now I am having an issue with the clutch sticking "open" normally it comes back together after you ride, but ours is sticking open. What is the cause of this? Oh yeah, it is a new belt as well. Any help would be greatly appreciated. Salisbury clutch...
    My cluctch was doing the same on my new to me Max IV (2004) I looked a lil closer and saw through the holes on the clutch cover some rush on the inside so without thinking I took some WD40 and sprayed in the holes and it solved my issues of it sticking open. Mine was so bad that it would stall out the engine if I let the sticks go while in forward.
      Clutch
      Gave it a try, doing much better, thanks!
