Hey early attex junkies,
I measured and posted a picture/diagram of the 2 styles of the 1" axle bearing.
I have some helpful info in the photo details.
The outside of the axle is smaller then the inside. So make sure you press it the right way. If when pressing them out, you mushroom the axles some. Just grab your angle grinder and grind it off. Also before you press, grind the axle sheer pin holes. Usually they elongate some and create a raised edge that interferes with the bearing pressing off. A file would work too but you cant plug a file into the wall socket.
I just bought 12 (6 per machine) outer bearings(the style on right of picture) off ebay for....
Subtotal: US $25.92
Shipping & handling: US $4.80
Total: US $30.72
Not sure of quality but I mounted them and they seem great.
Cheap enough at US $2.16 each.
6205 2RS Double Sealed Bearing 25mm x 52mm x 15mm - eBay (item 150403592009 end time Mar-08-10 13:52:42 PST)
Found them cheaper yet here, dang it, lol.
http://baileynet.com/index.php?dnfwd...ileyno=150-958
