Do you have a grooved axle and a shallow wallet? Well, here's the ticket for solving the problem without burning up the Visa card.
Repairing a grooved axle on the cheap:
1. Remove the axle.
2. Clamp it firmly in a smooth-jawed vice, with the groove about 6" from the jaws of the vice.
3. Using a wire brush in a 4" grinder, clean all the area in and around the groove, making it free of rust and gunk. Use a flat file gently on any high spots.
4. Use paper towels and wipe down the axle with solvent (I like Toluene), changing towels as they become dirty. Repeat until you have a 100% clean towel.
5. Mix up the normal 50/50 batch of J-B Weld
6. Using a 4" squeegee, fill the grooved area with J-B weld, making sure to keep the squeegee parallel to the axle. Use a light pressure. Don't use anything but a rubber squeegee. You'll be tempted, but DON'T use anything else! Been there...done that.
7. Wait 24 hours.
8. Go over the repaired area with 180 grit emery cloth at least 4" wide, wrapping it around the axle and pulling the ends gently. Stop precisely when the repair is flush with the axle. If you were good with the squeegee, this step shouldn't take much time.
9. Install the axle with a new seal and grease.
10. Go fill up your tank and take a long ride with the money you saved!
I hope this helps someone out. I have repaired two axles using this method, and having inspected them after two years of steady use, they both look like the day I did the repair. The repairs are still flat and true.
Sure, you could weld a repair, but then you're looking at having to chock the axle in a metal lathe and turning it down. Most of us don't have a lathe that large laying around, and the local machinist probably doesn't owe us any favors.
Planter Bob
Repairing a Grooved Axle
Created by:
Planter Bob
- Published: 09-15-2010, 08:07 PM
- 0 comments
Categories
article_tags
Latest Articles
by MikeFor anyone new to six wheelers, this is a short video showing you how to adjust the chains in a Max II. There are eight chains that need to be adjusted. The chains between the front and middle axles and the chains between the rear and middle axles are tightened using the ratcheting chain adjusters. The ones in the front are adjusted by pushing the adjusters down. The ones in the rear are adjusted by pulling the adjusters up. The remaining four chains are adjusted by moving the jackshafts. ...
Channel: General
03-14-2011, 11:05 PM -
by Planter BobDo you have a grooved axle and a shallow wallet? Well, here's the ticket for solving the problem without burning up the Visa card.
Repairing a grooved axle on the cheap: 1. Remove the axle. 2. Clamp it firmly in a smooth-jawed vice, with the groove about 6" from the jaws of the vice. 3. Using a wire brush in a 4" grinder, clean all the area in and around the groove, making it free of rust and gunk. Use a flat file gently on any high spots. 4. Use paper towels and wipe down the...-
Channel: General
09-15-2010, 09:07 PM -
by Rock DoctorWell, I finally got this little project started
Channel: General
06-07-2010, 09:05 PM -
by racerone3i've needed to redo the seats in my wild wolf for as long as i've had it. the seat back was the original and shot, and the bottom was something i had quickly thrown together. last week after months of my son begging me to take him for a ride in my old bronco, i finally got the back seat down from the rafters of my shop and bolted it in. later that night it dawned on me that it would make a pretty good seat for the Wolf. i checked with the place i'd gotten my seat covers form when i built the bronco...
Channel: General
04-13-2010, 09:57 PM -
by MikeGeneral - Purchasing your first six wheeler can be exciting and it is something that many of us remember well; Seeing it for the first time, the test drive, towing it home, taking it for a spin around the yard and realizing how quickly you can tear up the grass. But it can also be an intimidating process especially if you are not purchasing new. For some, a new six wheeler is simply out of the question. Whether it is financial concerns or simply that the six wheeler you are looking for is no...
Channel: General
02-28-2010, 01:23 PM -
by REB181How to bring the shine back to your HDPE Polyethylene body. Works on any 6x6 or 8x8 HDPE body and is simple to do.
http://s239.photobucket.com/albums/f...unbodyclip.mp4...-
Channel: General
02-12-2010, 08:50 PM -
