I just got a 2007 Argo Frontier that needs repairs so I am starting the project.
Transmission question??? I noticed that the transmission has 2 disc brakes on each side of the transmission, when I put it in gear only one disc turns, so I assume the transmission has problems. Can anyone give me an idea what may be the problem and how major the repair is? (Chains are taken off unit)
Sprocket Question??? I noticed the front sprocket looks like it has been sliding over on the axle. The kid I got the Argo from said the sprocket is supposed to do that. (I dont believe him) So are any sprockets supposed to move on axles?? Or should they all be locked down with a set screw in the sprocket to axles?
Brake Question??? The steering has a piston that that feeds into a mini brake cylinder then to disc brakes that are mounted on the transmission. When turning to left the piston is stuck and will not depress. So is this part just needing replaced??
