LED lights
  • #16
    if you follow the link it is to a shop that you are able to buy without bidding
    • #17
      tn.jpg fog lights came in got them mounted hopefully hook them up tomorrow will update when complete
      • #18
        These lights look great, do they make the replacement headlights for the avenger?
        I don't see any numbers on mine, only found the Argo Part # 613-159 online.
        • #19
          I can take a pic of my old bulb and you can match it up to yours if that will help also a update with the led replacement bulbs and the 18 watt led fog lights both on ( 4 lights ) have 12 volts at a idle and 13.5 at full rpm volt meter reads like nothing is on I AM STOAKED lol
          • #20
            ALso want to get me some for my Avenger....a pic or two would be great kezef!
            • #21
              the lights I bought were for a 01 bigfoot I looked up on line for a 04 avenger as they have different lights info I found said they are xenon 120 smd led headlights the same as for a dodge ram don't know if this is correct as I don't have a Avenger bulb to match it to hope this helps all interested John
              • #22
                My 08 Avenger 700 has 862 bulbs,
                Would I need a resistor to run these led lights?
                • #23
                  shouldn't as long as they are a replacement for your original bulbs
                  • #24
                    Originally posted by kezef View Post
                    thought this was interesting I found peimar lighting replacement bulbs for the power draining GE 894 headlights in my 01 bigfoot on Ebay for 17.99 a pair also found a pair of 4" led foglights for 58.99 figured I would pass it on John
                    LED lights are the best option in terms of brightness and energy saving
                    • #25
                      u ra
                      Actually, no for candle power (how you rate the output of light) it is actualy HID (high intensity discchage) How every, LED technology is fine for our application. Here is the link for the best, cheapest lights that i have found. HID & LED Lights For our purposes, the trapezoid pattern will be best.
                      ATV = Alaska Terain Vehicle
                      • #26
                        Hi guys,
                        I ordered these led's for my 04 Bigfoot off ebay thinking they were the same lights mentioned in this thread LED LIGHTS
                        Listing says they are 9W but also references 13W further down the page. I installed one to compare it to the OEM bulb and the LED is substantially dimmer. I would not recommend these specific bulbs as they are far too dim.
                        Can anyone provide a link or product number for bright LED bulbs that will work in the Bigfoot?
                        I run 37w LED lights on my tractor which light up my yard and would really like to find something comparable however these are square lights and won't fit the bigfoot opening.
                        A sealed flood LED light that fits in the headlight opening in the Bigfoot would be ideal...anyone found something that fits?
                        • #27
                          My 862 compatible LED 7.5w SMD off ebay didn't work on my argo, might try ordering a resistor next, the similar 16w SMD led fog light on my truck worked great
                          • #28
                            L.E.D.'s are polarity sensitive....try swapping the leads on the plug.
                            • #29
                              buggyman is right they should work, the polarity must be different on the hook up, alittle surgery on the plug should work for you. I put a the same lights in my 02 bigfoot. they work pretty good but not what i was hoping for. last year i put on a set of rigid industries led dually spot lights (15watts) on the front in spot pattern, not knowing what this lights were all about. I wish i had bought the flood pattern instead. the spot lights are great, more than 500 plus feet of light on the trails, but I wanted a little more light around the argo. This is was the reason for buying the replacement led lights for the stock headlights on the machine. They are not quite up to my expections that I would have liked. I guess you get what you pay for.
                              • #30
                                I would like to replace my 862 bulbs using LEDs. I want them to be brighter.
                                Sny help would be appreciated. Thank you.
