LED lights
  • #31
    You can get the replacement bulbs on eBay. But be are of the way LED bulbs are built they just don't put out the light. So far I have not seen a directional led replacement as of yet.
    • #32
      Otay. Any other lights you would suggest? I'm looking for something brighter than the
      862 bulbs.
      • #33
        Just depends what you want to spend. And what you need. I have been looking into Chinese LEDs. The have them on eBay for under $100 U.S. if I go with one I'm just going to wire them thru the original headlight switch. Also thinking of getting one for the back.
        • #34
          What I want and need are brighter headlights. Or maybe a few bolt-on types. LEDs suck less power, so I figure I might want this type, but will consider any type as long as they are bright. Thanks.
          • #35
            I've tried the led bulb replacement but the lights are dimmer than the original bulbs that came with my bigfoot.
            Now what I've decided to do is purchase the LED lights that will fit into the headlight openings on my 04 bigfoot. I purchased the newer rubber headlight bezels (613-74) which should fit around the lights nicely. Lights are 18w cree work lights which I've ordered but not installed yet.
            I also have these lights which I'm going to put on my bushguard
            • #36
              I found an 18" 72 watt led light bar on eBay for $82.
              I'll have to take a good night picture.
              • #37
                I'm very happy with it.
                See what effect it has on my battery life. I'm not sure how many amps it pulls.
                • #38
                  72Watts at 12V should pull 6 amps if my math is correct
                  • #39
                    That sounds more than the stock lights. I was thinking they only pull 4 amps. I could be wrong tho. Hope I don't have to pay for that some dark and snowy night.
                    • #40
                      Is that a flood pattern, spot or combo pattern?
                      • #41
                        Yes it is. I could easily run on these alone and not use my headlights at all.
                        • #42
                          I ordered a set of these LED lights for my MaxII. After sawing off the mount tabs they fit perfectly into the round light hole using the original rubber rings. They have 4 screw holes in the back.
                          2 x 27W High Output Spot LED Lights 4 3 inch Round Off Road Baja Bar Lighting | eBay
                          • #43
                            Awesome. That would give it a nice factory clean look. Any pics?
                            • #44
                              Send a link of the led light bulb that would fit my 92 magnum
                              • #45
                                What bulbs does your magnum take?
