While looking over my new (to me) argo I noticed some little metal balls sitting in the bottom of the tub. I recognized these as ball bearings and assumed, being that the argo is 30+ years old, that they were junk left in the bottom from some long ago owner. Upon some more observation I realized they were actually from a current bearing in the argo
I kicked the wheel and saw it move about an inch.
First thought was, "yeah! now I have a reason to rip into this thing" and start working on it. Second thought was "oh crap", this is going to get expensive quick.
I cleared the garage out enough to get the argo in, jacked up the right side and removed the wheel. Upon doing this I noticed that another wheel was spinning freely...the chains are still attached...Then I noticed the pins were gone in the sprocket that would hold it to the axles. I found them in the tub. They are bolts that someone attempted to tack weld into the sprockets.
So now the realization is setting in that it may take some time to get this thing back up and running. I've got some work around the property that this unit would make life a lot easier to do, but that ain't happening now.
So here is what I got:
1: One trashed axle, 1 1/4" pinned style
2: Trashed Inner and Outer Bearings on two axles (I believe the inner and outer bearings are the same size)
3: Slopped out roll pin holes on two sprockets (inner and outer on same axle)
4: 8 worn, weather checked tires (AT22x11-8's)
Here's my list of issues, I can start a thread for each if that would be better (Mike?)
#1: Does anyone have any advice on how to proceed on the axles and bearings? I have read the threads on upgrading the axles to splined and using the HD bearings. Not sure the budget can afford that. But looking for a replacement axle has also been an issue.
#2: Can anyone point me to sources for axles for the I/C Argos? This unit looks to be a mid 80's with an 18HP Kohler Engine. 1 1/4" axle, pinned...
#3: Tires, do tires really run over 100.00 each for these things? And where do you guys buy tires?
#4: Any other random thoughts or wisdom to share on the adventure I am about to embark on replacing axles and bearings?
I may end up tearing the whole thing down and doing a full rebuild but that would put me well into 2014 at my work load and cash flow before it would be done.
Thanks everyone in advance!!
Tom
Tom
