I'd like to hear if this has happened to others.
My 04 avenger spends its down time in heated garage. Currently, it's 20 or 30 degrees celcius below zero outside. I started my machine and parked it outside and let it sit for 30 minutes so the machine can get to outdoor temp (snow less likely to stick to body and wheels and form ice). After 30 minutes, started the machine no problem and let it idle for 10 minutes. After that I began my ride but machine stalled within 100 yards. Able to start it right away but only with choke. As soon as I took choke off, it stalled. This went on for 5 minutes then I just let it sit for 10 minutes. After 10 minutes, able to start it right away no problems. Just made it back home (about 100 yards) then stalled.
It took a lot of head scratching to solve this puzzle. Here's what we came up with:
In the last two weeks, I used me my argo a lot in the snow with tracks. Snow was blown in the fuel vent at the rear of the vehicle. When the vehicle went back in the heated garage after its run, the snow melted in the vent tube and collected in a low point of the tube. When I took the argo out of the garage and let it sit for 30 minutes in the deep freeze, the water in the vent tube froze. Because the gas tank was no longer venting, it created a vacuum and starved the engine of fuel. Back in the heated garage it went. The ice in the vent tube melted. Once I clued into this, I was then able to blow the water out of the tube and problem solved. There wasn't much water but the tube is small so it doesn't take much to obstruct.
Question: Why is it so important for the gas tank to be vented so far back and at that precise location? It seems likely that water, snow or debris will enter to venting orifice and obstruct the tube. The argo really stirs up alot of mud, water, or snow back their (especially with tracks). Unbelievably simple but you're going nowhere if your tank is not venting.
Solution: I will be redirecting the vent tube to a more protected location.
Keep this in mind fellas
