First contact with Argo mechanic
  • #31
    Originally posted by Vortex View Post
    Went out easy with my impact!!!
    I did the upgrade suggested by RD...here is the video:
    As you can see in the video something seems to be odd with my block...Is it supposed to be worn like this?
    Thanks!
    Vortex
    I'm thinking you mean that it looks odd, the way the Lead Weights are "smeared" a little bit? That is normal, it has to do with how centrifical force throws the weights out, the weights push on the clutch cover.
    Did you put any kind of lube on the clutch components when you reassembled? I use a Dry Graphite spray.
    How do you like the way it performes now?
    • #32
      I did not reinstall the clutch yet...I wanted to be sure that the wear on the weight was ok...I will try to find graphite lub tomorrow...But with the forecast of 10 inch of snow...I am not sure i will have a oportunity to test the thing. Maybe i will try to do the mods on the secondary too, will see tomorrow.
      Click here to see my hunting video:
      https://www.youtube.com/user/vortexw...?feature=guide
