argojim,
The Front chains are extremely loose and looks like the trans chain is shot, its all stiff. The left side of the argo needs all new tensioners the back two are broke upper and lower. I pulled the rear axles out to check the bearings and it looks like on the outer bearing there is a flange on the outside but not on the inside. The outer grease flange is egg shaped because the axle was just flopping around. So my question is there should be 2 flanges a bearing right? inner and outer? How can i fix the excessive flop on the front two chains?
Thanks,
Derek
Thanks,
Derek
