I just got in 6 new rocker switches for lights, brake fan and such. I am about to order a new rocker for the winch just make it look nicer. And was thinking of adding another rocker for a horn, just to be safe. So instead of cutting a 8 holes in the dash. I though it would be easier to cut one. But I cant find a mount that will hold all 8 rockers. I did how ever find 1 that will hold 6 and 1 that will hold 3. I can get a plug for the 9th hole. My question is, is it going to be ok to cut that much of my dash out? I could if I really had to cut it down to only 6 switches if I had to. But I think having the extra space incase I need it in the future would be a good idea. What do you guys think? Thanks for any and all comments.
Cutting on Conquest dash
I'm not sure there is enough room on it or behind it to do so as there are a lot of tightly run wires behind it. If you were to place it on the opposite side of where your vin plate is may be better but harder to see, unless you have a heater kit which the vents would then be in the way.sigpic
I was looking at that. There is a group of wife's there. But I think they would push out of the way enough to get the switches in. My biggest worry is if somehow cutting a hole would take away from the structure of the argo. I don't think it would, bu thought I would ask just to be safe.
Thanks. That's the answer I wanted to here. You machine looks great by the way.Originally posted by XVR View Post
Correct. A fuse block negates the need for inline fuses. I apply masking tape, draw my hole (with a shop vac hose behind it to cetch cuttings) the muse a saber saw. The worst that can happen is it will leave "fuzzies" around the hole, but a pocket knife will clean them up.'also, if you put a cover over that, no one will know if your hole is crooked but you
ATV = Alaska Terain Vehicle
Well I'm not completely happy with it. But nothing I can do now. The saw got away from me so I have a little gash in the dash now. But over all it will work great. Here are a couple pics.
Also like any project. I have opened a can of worms. Noticed that some of the wiring in brittle and is going to need replacing. But this beast is well worth it.
