Been done at least twice. Youtuber guitarhack42 posted a chronicle of his swap and Rock Doctor provided links in this thread. Rock Doctor also made this swap and proves it in this thread.
So, high elevation playing in the snow on tracks had convinced me that I NEEDED more horsepower. In this thread I mention a pretty easy engine modification that gains a smidge more than 10% horsepower for the FD620D and I was pretty sure this is the route I was going to pursue. Later in that same thread I explain how I ended up with a big block Kawasaki FD791D sitting on my garage floor.
Dimensionally, what are we talking about?
(left is Fd620D right is FD750D)
Hmmm, the PDFs were too large to upload and the jpg conversion leaves a bit to be desired but these are the documented sales dimensions from Kawasaki. A search should find them - I downloaded them when I found them so I'm not sure where they came from. The spreadsheet shows some important dimensional differences. Units are millimeters.
What we see is that there are mounting bolt locations on the 750 that will put the flat face that the driven pulley indexes on in plane with the same on the 620 and 8.5 mm higher vertically. Close enough that this is no issue. The gross dimensions (think of it as a box) tell us that the full engine package of the 750 is slightly smaller all around except for and aft by a few millimeters. The shaft is 16mm too long and the radius from the shaft to the shoulder is 2.5mm greater.
From this I will use the same bolt holes for mounting but will need to drill them a bit larger. I mounted the engine in my turret lathe:DSC00629.jpg to cut off the extra 16mm (used a hacksaw and beveled with a file) and drill/tap the center hole. You can choose to cut the bolt shorter. As for the radius change I will mill the driven pulley, probably in the same turret lathe
, to put a 2.5mm larger bevel on the inside surface.
There are other dimensional issues to deal with that will make more sense to talk about as I get to them. In fact, right now I have the power pack apart and I'm about to modify the engine mount. I'll take pics.
There are fuel system differences. I have stuff to show for that.
There are electrical differences. I have drawings to show this.
I go slow because I do lots of stuff. The project stalled last spring because of walleye tournament season and garage remodel and ...
... but now I'm on this again.
Oh, and since the power pack is out I am throwing installing a bilge pump and upgrading the front axles to HD because it should be pretty easy now. Also, the 620 has an alternator and I am going to move that to the 750 - there are quite a few dimensional issues with this.
