Alternator Install - Outside Bracket
That is the finished bracket that the alternator attached to. 3/16 steel. Kind of strange looking at the picture because the shiny spots make it look a little different than it really is. At the top of the slot is a small metal tab with a hole in it for the tensioning screw.
hmm.
Okay, you can see (this is the FD620D) how the upper bracket has a tab for the tensioning screw.
Because my bracket wraps around the back side of the alternator I couldn't bend a tab here. You'll see.
Right in front of that is shiny because I had to grind off the weld bead. Whoops. It created a clearance issue with the tensioning block that I forgot about when I welded it up. Don't do that.
I did intend on just bending the pivot side of the bracket but the cardboard template maker didn't account for the material thickness and I had to weld it up. Actually, I think welding it is an easier approach anyway.
The three installation holes are match drilled to the inside bracket. The slot I made by putting the alternator in the bracket and carefully, with a bit that doesn't ruin the threads, marked center holes while pivoting the alternator in the bracket. Then, with the alternator off, drilled through on the press and cleaned up with a dremel tool.
Anyway, when it is done it looks like:
Spacers: 2 9/16 inches.
Bolts: M8x1.25x90 but 85 is the right length. I couldn't find them. 90 works fine.
Install the inner bracket first because you cannot install the middle bolt when the outer bracket is installed.
Attach the alternator to the outer bracket before installing because you cannot when the bracket is installed. Everything is in there pretty tight.
The belt is the L-319 that came with the alternator kit.
I did some mock ups and really feel that there is clearance for this in the Argo. Fingers crossed.
I do anticipate that I might have issues with the brake cooling air hose. Another reason it makes sense to use the kit ArgoJim mentioned.
[I'll attach the scaled template for this bracket here when I know how]
I show the installation holes on this on just to give you an idea where I put mine. The only critical part is that you don't put the upper hole such that you can't get to the tension screw when you are done. I've marked that with an X.
To match drill you match up both brackets at the common curve. They fit pretty well. I drilled the middle hole first to 7/32 and then remembered that I use 3/16 rod for pins. So, I turned that drill bit upside down and used it to pin the middle hole and then did the other two holes 3/16. That's why it looks bigger.
I meant to do that.
Oh, by the way, I think this could be installed without taking the radiator off, you know, if your engine is already installed.
And oh yeah, I did not paint it. Nobody look. I was contemplating the fact that the bracket is the negative side if the alternator circuit and what to do about it after the install you see in the picture, which was supposed to be yet another fitment test install, when I noticed that it was installed and would work just fine mechanically and electrically... and it was already installed. So, if you paint or powder coat it you will have to ensure you have a ground path for proper functioning of the alternator.
hmm.
I do anticipate that I might have issues with the brake cooling air hose. Another reason it makes sense to use the kit ArgoJim mentioned.[I'll attach the scaled template for this bracket here when I know how]
I meant to do that.
