Used Argo
  • Used Argo
    I might have a chance to buy a 2010 HDI argo, I am just getting all the info on it,I can tell you it was privately own and it has around 300 hrs on it,I was just wondering if anyone out there could tell me if there are any factory problems with this year of a machine.I know that this was the first year that the HDI units were release.
    Nice machine...there are 2 transmissions available for this unit..6.4 ratio for tires or a higher torque 8.4 for track or heavy loads....I prefer the 6.4 ratio... be sure its the one you want....on top of the tranny you will see the number 6.4 or 8.4 ...good luck on your purchase.
    Tracmaster
      Expect to replace some parts at 300 hrs. Just saying, be aware, add in about $1500 to the purchase price...
        Hopefully it's in good shape and is what you want!!
        Camo side up, Rubber side down!!
        2014 Argo 750HDI SE
        2008 Honda Rubicon, Camo
        2008 Jeep Rubicon, Black, 2 door, 6sp, 2 Warn winches.
          early build 2010s were actually better than late 2010 and 2011.just make sure it has round muffler .some later 2010s and all 2011s had hexagonal mufflers creating heat problems (melting plastics). also the excessive heat build up created problematic trans troubles(ie.melting locktite on some internal parts and weakening)
            Thanks for the reply's,Like I said just getting all the info. on it and I will have to go have a serious look at it if I at it,if the price is reasonable.
              Good tip Lundnargo. Hopefully the hood fan kit that's available now can help with those machines.
              2014 Argo 750HDI SE
                I have very early HDI. ODG papers say its came out of factory 05. november 2009. Im second owner. First owner didnt done himself service things but maintenance was done by local workshop. He use Argo at water and also he stores river water in chain tunnels. Chains was rusty and bad shape. I use Argo almost in that shape 2 winters. Of course I chance oils and etc.
                For this winter I have chance 6 outer bearings and all chains. And also I have chance one handbrake caliber and brake pads.
                It has now 1060km and 280h. I use it mainly with rubber tracks and dont have track tuners.
                I have been pleased my HDI. Only problem here in Finland is that local dealer doesnt have spare parts in his storage so it tooks almost weeks to get parts. I try to keep few of parts in my storage that I can use Argo if something break down.
                Marko
