Rod, while it is not ideal or even good to ride the brakes for any extended amount of time, light amounts of pressure are normal to most drivers on trails and or in mud holes. This allows the differential to work the way it wants, riding the brakes for minutes will certainly cause the brakes to over heat.
The older mechanical brakes were prone to overheat from riding them partially do to the lack of a cooling fan and the close tolerance of a properly adjusted manual brake not having time to cool. Newer machines with the fans are fairly good about heat relief from feathering, not necessarily riding but feathering.
My dad has been jerkin it since the 70's ( in his head he's still driving the 76 2 stroke though the tight woods with a broken axle shear pin)and while it does create less heat on the brakes, it does not create less stress on the machine or passengers.
. Sometimes I'm loaded so heavy that I have no choice to make jerky turns in some terrain
