Advice on Lubing Chain
  • #16
    Rusty gun
    Hi,
    Wheel bearing grease suitable for under water operation will either have a
    lithium / calcium base found in a 220 and 460 thickness shell brand
    or aluminium base found in a 120 base thickness many brand Dupont
    220 thickness is ideal amphib only
    120 is ok in boat trailer and amphib
    I dought these are suitable for chains as there thickness would not allow them to flow well enough.
    A friend uses chain and bar oil [chainsaw ] paints on with a brush
    For an o ring chain try the spray wax grease for motor bikes [previously mentioned Du pont chain saver .]
    To much excess oil and grease in tub attracts dirt sand etc
    tomo
    • #17
      Thanks Tomo.
