Hello - I am looking for advice for lubing the chain. Interested in brand for spray lube for the chains. Thanks for your advice... Have 14 HDI 750 that I need to upkeep...
Advice on Lubing Chain
I use Dupont Chainsaver. Get it at Walmart. It is a teflon/molybdenum dry wax lube. I like it because sometimes ride in the sandhills of Nebraska. The fine silty sand there will goober up anything with exposed oil/grease. It's hell on combine/bailer bearings and chains.
Some folks don't like wax lubes and I hope they come on and tell us why (I don't remember) but I've had no problems yet. It's pretty easy for me to spray a bit on the chains every so often. It also doesn't make a huge mess all over inside the machine.
Sol, don't think the good woman would appreciate you using that for lubing chains
We made the luber and bubbler ages ago for various items, all out of an old propane cylinder (don't know the size but about 2 ft high.)
Get an old cylinder, remove the valve and fill with soapy water for a few days. Then cut the top off, about 5 or 6 inches down. The bubbler uses the bottom bit, all you do is weld some brackets about 2 or 3 inches from the bottom and drop a piece of good weldmesh / perforated steel on the brackets. get an aquarium pump and run the air pipes down the inside and under the perforated steel. Fill with kerosene to the desired level and turn the air pump on. leave items to be cleaned in for a few days to remove all crud. we usually rinse in a tank of thinners.
The vacuum tank uses the top part of the cylinder. Weld the hole up where the valve was and run a length of rubber edge trim around the cut edge. drill a hole just down from the cut edge and weld an air spigot in it (this is where the vacuum pipe goes).
Fill to desired level with thick oil, drop chains in, cover top with suitable material ( we use a piece of 1/4" unbreakable acrylic (Lexan ?)) connect up vacuum pipe and turn pump on. When bubbles stop appearing from chain links turn pump off and let air back in the tank. You can see the oil level drop as it goes into the links / rollers.
We usually leave it a couple of minutes to allow good penetration.
Hi
NON O RING
needs a lube that will penetrate into the pins
I have used ROC OIL spray
It sprays thin until all the propellant/solvent evaporates .Being thin helps it penetrate
Leaves a residue that semi dries to a only slightly sticky residue .
After 4-6 applications it leaves a very tacky residue [build up ]
I lube chains every time or every second time I use my 6x6
NB I have tried other spray s and the ROC OIL has the least amount of fling off .The chain cannot be lubed well if u find it all over the body ha ha .
As u would expect the wax sprays are thick and have little penetrating qualities
tomo
n
Originally posted by Tomo View PostHi
NON O RING
tomo
n
HI Rodp
Agreed with your methods .The other method I use is to use an old pot or a new one just watch your wife !! Place chain in with 140 grade oil and heat to 70 celcius. After 1 hour all good .
The vacumn method sounds great ,but I would only remove chains when I have to . The access to my chains is only average . I degrease chain and tub at the same time around every 6 mths . The 1800psi pressure cleaner works great removing all the grime /dirt oil grease with drain plugs out .
tomo
