I just got my 1st Argo home and have decided to go completely through it. I had originally thought I would replace a few bearings and chains and go, but on closer inspection it needs a little more love.
I have split the body and removed the bolts for the engine and transmission. I need to split chains now but have never worked with a double chain nor a chain this size. Can someone recommend a chain breaker?
The metal floorplan has some significant rust so I will cut that out and replace. Once I check the rest of the frame for cracks I will sandblast and powder coat the frame. I will go back with all new bearings, brake pads, and chains since I will already have it apart. Is there anything the I might be missing since I will have it apart that I need to replace?
Also has anyone tried to coat the tub with Rhino Lining? Was wondering if that would be a good thing or a bad thing.
I will be adding tracks as I go back together so if anyone has some for sale please contact me.
