I'm just wondering if anyone has tried a electric motor mounted off the front end, turbulence should not be a problem then?
Trolling Motor on Argo ~ Best amount of thurst etc/ brands suggestions plz
You guys should invest in a larger diameter prop with a smaller pitch. No point having an outboard that was meant to move a jon boat or zodiac at plane, your outboard can never get an argo up to the power band or you will just cavitation.
A larger diameter prop will give you more thrust, and with less pitch you will get a slower top speed than the outboard was designed for, but will push better.
2 30 pound thrusters will move you better than a single 60 because you have more prop surface area.
