I need to remove a right front axle from an earlier (95)Response, however the axle is probably seized on the inner bearing or possibly outer. The sprocket is free and can move and i've got all the bolts off the bearing extension and set screws etc.
I'm just finding that pounding on the axle is not enough as the power pack is right there and you can only swing 3 " max. Any suggestions? Is the best bet to just remove the complete power pack? Don't realyl want to pull that unless necesarry.
Neeed to replace the cork seal.
If so looking for a sequence on that as the manual doesn't say much.
thanks!
thanks!
