First off, hello all. I'm new here and to Argo's.
Did what I thought was a good idea last week. Bought a 2000 Conquest for dirt cheap. Has tracks and a plow and the main reason I bought it was to plow my drive and haul firewood around my property.
Didn't run when I got it, no fuel. Replaced the fuel pump, tore down the carb and cleaned it out. Fuel shut off froze so I cut off the pintle so I could at least hear it run. New fuel and filter. Checked the lines for leaks, ok. Started right up and run pretty well after that. Drove it around about 30 minutes.
Problems:
1 - Engine smokes (oil) like an old freight train. (checked but didn't change oil or filter)
2 - Seems low on power. In low and climbing a hill of about 40 degrees I need wide open throttle to make it up the hill and it is struggling. (1 person in machine, not towing)
3 - Charging system not working. 12.2 volts at any rpm, headlamps on, 11.9 volts at any rpm and dropping.
Machine has 150.3 hours on it. Engine is a Kaw 20 HP FD620D, slight surge at idle, no overheating, smoke is blue with the telltale oil odor.
I've been an auto tech for well over 20 years but I'm not so sharp on these little things.
Any input would be greatly appreciated.
Thanks all!
Problems:
Thanks all!
