Removing spacer on rubber tracks?
  • Removing spacer on rubber tracks?
    When do you guys recommend removing this spacer? I have about 160 miles on 2015 750 hdi. Tracks seem quite loose with recommended air pressure and seem to be really pushing on side walls in ruts. I do know my one side is looser then other side. I also know that too tight is not good as its hard on bearings. Would like some other owners input on this. I did puncture a side wall today in a rut. Its very small and hoping i can patch it.
    2015 argo camo 750hdi- rubber tracks, bilage pump, rear hand rails, winch, brush guard, alternator, heater, full soft cab and windsheild.
    What air pressure are you running at?
        Jack the machine up and check for sag, 1.5-2 inches it's recommended. If sag is excessive then remove it, if not a pound should cure it.
        Keep in mind too much air pressure and though your body does have the rear support kit in it which will help with some clearance.
          Someone read my mind. I have the exact same question, and the exact same problem with the tires. Following.
          sigpic Peace and Solitude of the worlds forests can be crushed by 1 broken part....
