When do you guys recommend removing this spacer? I have about 160 miles on 2015 750 hdi. Tracks seem quite loose with recommended air pressure and seem to be really pushing on side walls in ruts. I do know my one side is looser then other side. I also know that too tight is not good as its hard on bearings. Would like some other owners input on this. I did puncture a side wall today in a rut. Its very small and hoping i can patch it.
Removing spacer on rubber tracks?
Jack the machine up and check for sag, 1.5-2 inches it's recommended. If sag is excessive then remove it, if not a pound should cure it.
Keep in mind too much air pressure and
though your body does have the rear support kit in it which will help with some clearance.
