Hi guys,
I'm having some trouble getting one of my idler chains on.
The right one (as you are sitting in it) went on easy enough,
But for the life of me - I can't get the left one in.
The chain is definitely the right length (triple checked)
I even made a tool that used a bolt, and two claw like hooks welded onto some nuts.
This worked so that when you turned the bolt, one claw moved towards the other and brought the chain ends together...
I tightned this till it was very VERY tight... and it was still short by about 3-5mm or 1/4-1/5th of an inch.
I'm at a loss as to what to try next
I tried putting in an extra link in and two clips, but once the idler chains are tightened, the powerpack is canted over to the right badly. This works, but I'm unhappy with it.
Would lifting the whole powerpack up from the front engine mount a few inches reduce the distance between the the sprocket and jack-shaft?? or just make it longer?
Is this an indication that the power-pack frame is twisted?? or that soemthing else is wrong?
if anyone has something else to suggest - I am all ears....
(FYI - the mood I'm in - "set fire to it" is a valid suggestion at this stage
cheers,
Mitch.
)cheers,
Mitch.
