First time in the water with my conquest for about 30 minutes an I got about 2 inches of water in the tub. What's normal ?
Normal water intake
With my experience you should have very little to none. I have ran for hours in the water with no water. Sometimes water comes in while entering or exiting water. I would start with checking bearings, bearing gaskets, then drain plug seals, and then tub.
Sounds as if the axle seals have worn, check for bearing movement up/down. There should be 0 in a new bearing, when lifting/lowering axle if play is evident those bearings should be replaced and if aluminum housing is wore replace it also.
If your machine has tracks check the lower body for a rub through near corners under rear seats and under radiator/exhaust (mainly) and along entire sides.sigpic
