Well I have had the 750 HDI 8x8 for approximately 8 months, and I gotta say I am still on the fence. My current set up has the Argo rubber tracks, Argo heat tires(now), windshield, 2 wipers, full canvas top, box liner, homemade heater, homemade junk box, homemade headache rack, 20" LED light bar, 2 LED pencil beams, 4500 Superwinch (that has never been unwrapped), Adair transport cover.
I have just hit 100 hrs on the machine and I think this could help new buyers and old. This is just my experiences and I cannot comment on how others machines work. I believe I drive responsibly and don't believe I have ever pushed this machine past what is wasn't intended. The price for my unit was $32k All-in which in itself is crazy now looking back. My history for the last 10 yrs has been SxS and quads.
I use this machine for working a trap line (all year), hunting in spring/fall and the occasional river fishing trip/ camping in summer.
The Good:
1. It floats and has been very stable in all my applications (lakes & rivers). I use a elec trolling motor in deep water
2. I haven't been able to get it stuck (trust me I've tried lots), in holes that sink SxS and quads
3. fuel efficient
4. Hauls everything and then some
5. Climbs anything ( I will chicken out first)
6. Low impact on sensitive ground as long as you don't turn
7. The Adair cover, trailers at 120 km/hr no problem
8. The motor and drive train are not dragging through he mud and stumps which to me can only be a good thing
9. It has been great on the river ice, even when a break through happened.
The Bad:
1. The stock Argo tires were garbage. Literally delaminated in less than 50 hrs. Argo did step up and replace all of them with heat tires at a cost of $400 to me. I have only run tracks. Argo said they never seen that before. The HEAT seem good so far..
2. I don't understand the tightness of the tracks. Argo dealer says they are good, I say they are too loose as they hit the bottom of my tub when I hit a bump. I don't get why they can't take out the spacer plate and lower the pressures more if required.
3. The canvas cab, fits like crap. It is loose in the front, it sags in places. I cannot adjust the front tension as it then prevents the sides and back from fitting.
4. The windshield is 6" to low on the top. You are constantly bent over and it is a strain if going all day
5. The wiper is slow and grossly under powered for snow. I moved it and added another to help the work load but it is still brutal
5. The axle extension bolts sheered right off on 1 tire (2nd DS) and were loose on all other tires. Argo spec is 40 ft/lb and claims that no re-tightening is required unless you remove the studs. As Argo did the tire swap, I need to think that they did not torque these properly.
6. NONE of these tires will hold a pressure.They constantly need checking(daily). It's annoying especially x 8 and after dealing with a frozen river daily (ice build up)
7. They are the roughest machine I have ever rode, I used to think it was the older Honda quads, not anymore
8. The 12v plug and USB plug-in is broke and I swear has never been used.
9. Why these units don't come STOCK with chain lubrication is beyond me. This could be a cheap factory addition and save so much frustration of having to remove cargo boxes (100 lb +), tubs, pans and plastic for a 2 min job, never mind doing it with the top up and -20 deg.
10. It is SLOW, brutally slow. Don't ever tell someone you will meet at a certain time, cause you will be late.
11. Changing oil is an SOB. input special suction tool here
12. Argo brand accessories are ridiculously priced. (eg. heater, wiper, windshield, alternator etc.) Switches, cables and maintenance parts seem reasonable.
This is my official application to be head of the ARGO R&D department as I believe either there isn't one or the person has never ran an Argo EVER.
You can contact me via the site if you would like to receive a test drive in your own unit, and check my qualifications.
I'd like to hear if I am truly the only one with these issues? Most things are just Extremely annoying, but for 32k it isn't worth the annoyance. I can say so far I am regretting my purchase. I could do up a lot of machine for 32k, even a SxS
